Kickdown or vacume
Old Apr 2, 2001 | 02:21 PM
tbejr's Avatar
tbejr
Kickdown or vacume
I just installed a c6 with my 360. I have a 70 f100. It came with vacume modulator hose from modulator to carb. Do i need kickdown linkage to the tranny too because it does not have it. My 2nd gear shift is 7 mph and 3rd at 15mph. I even adjusted modulator screw all the way in and out.
Thanx
Thomas Endicott
Old Apr 2, 2001 | 04:43 PM
jowilker's Avatar
jowilker
Kickdown or vacume
You may need a new mod. valve, and yes you need the kickdown too. Someone else may have a better answer for you on your shifting points.
Good luck, on making that truck shift it's own gears. ;-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Apr 2, 2001 | 09:23 PM
farmerx2's Avatar
farmerx2
Kickdown or vacume
The C-6 trany requires both a vacuum modulator and a kick down rod for proper shifting. Also the modulator has different leangth pins.
Old Apr 3, 2001 | 07:37 AM
Ratsmoker's Avatar
Ratsmoker
Kickdown or vacume
Old Apr 3, 2001 | 11:39 AM
tbejr's Avatar
tbejr
Kickdown or vacume
Thanks for the reply guys, I appreciate it..
Old Apr 3, 2001 | 06:41 PM
Franklin2's Avatar
Franklin2
Kickdown or vacume
I've got that problem with my c4. I know what caused it, but don't know the best solution. The trans I put in my truck came out of a car with a 2.? something rearend ratio. My truck has a 3.90 ratio. Of course the trans doesn't know the difference in rearend ratios and shifts early with the 3.90 ratio. I am not sure, but I think the factory made slight changes in the control system of the trans depending on application. (like governor weights and springs etc.)
