egde juice
Old Feb 25, 2006 | 03:17 PM
deanroller's Avatar
deanroller
egde juice
have a 7.3 with edge juice with attitude and it is throwing a crank sensor code and a wastegate code and the truck sometimes stalls any help
Old Feb 26, 2006 | 12:34 AM
BuickTurbo's Avatar
BuickTurbo
Is your wastegate still hooked up (red line)? If it is, unplug it. Disconnect batteries for 10 minutes and see if it comes back. (plug the red line onto one of the threaded rods from the nearby boost tube boot)
As far as the crank sensor goes, that is just a part that fails due to nothing more than it's simplicity.
Old Feb 26, 2006 | 02:34 AM
jtharvey's Avatar
jtharvey
Is the wastegate code an overboost code? Before you disconnect the batteries, can you get the code number and post it?
Also, what about the crank sensor code number? Sounds like you've got a CPS failing. That will sometimes set a code, and would also explain the truck stalling.
