1966 - 1977 Early Broncos
Fuel tank 77 problem??
Old Feb 25, 2006 | 03:09 PM
bbqman2000's Avatar
bbqman2000
Can anyone tell me what I need to do ? The sending unit ohmed correctly, but now in tank not working, it showing empty but it has 3 gal of gas.
Old Feb 25, 2006 | 05:16 PM
1bad73bronco's Avatar
1bad73bronco
I put a new sending unit in, and now it always says it is full, and I have run out of gas twice. Anyone help?
Old Feb 25, 2006 | 05:34 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome bbqman to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 28, 2006 | 07:46 PM
1bad73bronco
Anyone know???
Old Mar 1, 2006 | 05:30 PM
68 351 bronc's Avatar
68 351 bronc
The sending unit works off of a resistance to ground.
One wire to the sending unit is a ground wire.
One wire runs from the gauge to the sending unit at 1.5 volts (from memory).
No ground reads empty
Strait to ground reads full.
