More Axle questions
Old Mar 30, 2001 | 10:59 PM
greg58's Avatar
greg58
More Axle questions
Old Apr 4, 2001 | 09:06 PM
mcrank's Avatar
mcrank
More Axle questions
How Tough exactly is a 9" axle and a dana 44? And is it possible to cut a duelly axle down to a tough one-tire axle and would it be worth it? The duelly is from a 70's or so f-350 I think.
Old Apr 4, 2001 | 09:57 PM
coilsprungf350's Avatar
coilsprungf350
More Axle questions
The 9" and dana 44 are fairly strong if you are staying with smaller tires (ie: 35's or smaller)....if you go much bigger than that you risk a chance of blowing axle joints in the front end all of them time if you use it. The rear will stand a little more, but if you change gears to accomodate the larger tires you will have a heat build up problem. As far as cutting down a dual wheel version...I wouldn't recommend it. The dual rear end is more than likely a Dana 60 or 70...and single wheel ones are readily available in any junkyard. The single wheel ones are just as strong and will bolt up to your existing stuff except for the wheels. The only thing that I can think of that may be different is the spring pad width...meaning for 2.5" springs or 3" springs....but that is easily adapted.
