9 inch swap
Old Feb 25, 2006 | 11:23 AM
DictatorDanny's Avatar
DictatorDanny
9 inch swap
Hi. Im planning on swapping out the 8.8 and putting in a 9 inch from a 78, 79 f150 or Bronco just wondering how bad it could be. I am going to put in 4.56 gears to match the front and a spool. I dont think it could be hard the only things im worried about is the speed cable that goes to the 8.8 and how the driveshaft bolts to the plate on the 8.8. And i was wondering do the brakes and stuff like that swap over to the 9 inch from the 8.8.
Old Feb 25, 2006 | 03:14 PM
chrono4's Avatar
chrono4
its all the same. brakes will be the same, driveshaft should be the same, same spring pad width. what year is your truck? it will bolt right up unless you have a vehicle speed sensor on your rear diff, then it gets hairy.
Old Feb 25, 2006 | 04:31 PM
MustangGT221's Avatar
MustangGT221
https://www.ford-trucks.com/forums/s...d.php?t=463669
Somehow his is a popular topic lately lol.
Old Feb 26, 2006 | 11:11 PM
DictatorDanny
My truck is a 94
Old Feb 27, 2006 | 08:58 AM
Kemicalburns's Avatar
Kemicalburns
the break drums are different. but since yours is a 94 the speed sensor is a must. why not put that stuff in your 8.8? a lot less hassle
Old Feb 27, 2006 | 10:43 AM
s8whiskey's Avatar
s8whiskey
If you are doing a swap with all this stuff and doing the project why not get a full one ton axle. sterling in the rear and d60 or something in the front?
Old Feb 27, 2006 | 09:19 PM
chrono4's Avatar
chrono4
if you wanna upgrade axles then, then you have to keep too newer axles to keep the vss.
