Changing transfer case oil
Old Feb 25, 2006 | 06:45 AM
happycamper116's Avatar
happycamper116
Ok, I am getting ready to change the transfer case oil and if I have read everything right I am just to use mercon atf, is that correct? I have quaker state. Anyway I crawl under the expy to check it out and I see how you drain the oil and all but what is the best way to get the new oil back in. What I bought is just in a regular quart oil container. Any suggestions on this.? Thanks Brian. Sorry for all of the questions but I am trying to become a Do-it-yourselfer.
Old Feb 25, 2006 | 07:03 AM
EagleDakota's Avatar
EagleDakota
I just read a recent post here that had a great tip: remove the filler plug before you drain the transfercase of oil. That way you know for certain you can refill. Apparently sometimes they get stuck. Also it will likely help to dran faster. Good Luck!
Old Feb 25, 2006 | 07:09 AM
happycamper116
Thanks for that tip, sounds like a good idea. Now I just have to figure out how to get the new oil back in without turning the expy upside down.
Old Feb 25, 2006 | 07:17 AM
EagleDakota
Use a suction pump. You can buy them cheap at WalMart or an auto supply store. I also read that boating supply shops sell a gadget that pumps directly from a one quart bottle. I'm going to check that out myself.
Old Mar 1, 2006 | 11:57 AM
c_hohensee's Avatar
c_hohensee
to refill the transfer case you do indeed need a pump. The best one I have found screws into a quart bottle, I found it at Checker auto supply
Old Mar 1, 2006 | 12:59 PM
ford390gashog's Avatar
ford390gashog
you need a pump. walmart or napa for 4.00.
Old Mar 2, 2006 | 03:36 PM
aagitch's Avatar
aagitch
Smile
Hi, I'm going to be changing the transfer case oil in my 03 as I have a small leak coming from the case cover gasket/sealant. I see the plug where you add the oil, but where do you drain it from? Do I just pull the darn cover? Thanks
Old Mar 2, 2006 | 07:39 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome aagitch to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 2, 2006 | 10:36 PM
aagitch's Avatar
aagitch
oops! I had a brain fart. I was talking about the front axle/differential. It's has a small leak at the cover. I see a fill plug but no drain plug.
Old Mar 2, 2006 | 11:17 PM
ford390gashog
the front is a 8.8'' you remove the cover and reseal it with a bead of black rtv silicone.
