General Automotive Discussion
chevy wont start
Old Feb 24, 2006 | 11:49 PM
Jack-USAF's Avatar
Jack-USAF
chevy wont start
ok. its a 1975 chevy 1/2 ton pickup with a carburated 350. its getting spark and great compression. it smelled like it was getting way too much gas at the carb, so we adjusted the air/fuel screws. now it is getting less fuel but still wont start. it tries to start but it wont. please help. any input would be greatly appreciated.
Old Feb 25, 2006 | 01:12 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
More info needed. Was this a normally running vehicle that developed a problem, a vehicle that has just had work done (for example, new upper end that you installed), or one that used to run fine, sat for awhile, and now when you are attempting to start it has this problem?
*If it's flooding when you try to start it, you can turn the idle mixture screws in all the way and that still isn't going to be enough. Stuck float? Initial idle setting high enough?
*If you've completed work and it wont start, is your base timing correct and along this line, any chance you've got the timing off 180 degrees?
*Does it even bark when you try to start it?
Old Feb 25, 2006 | 01:41 AM
go_racing84's Avatar
go_racing84
Have you tried holding the throttle to the floor while cranking?
Also, how old is the gas in it?
Old Feb 25, 2006 | 01:46 AM
73Fastbackv10's Avatar
73Fastbackv10
Did you have the distributor out? I'd recheck the distributor cap with the firing order.
Old Feb 25, 2006 | 01:57 AM
Jack-USAF's Avatar
Jack-USAF
it was a daily driven vehicle and then one day it started running like crap but he could still drive it a little bit. and finally it completely quit starting. no motor work at all. we already messed with the idle screws. its getting fuel and spark. has excellent compression. it just wont start. has a recent tune up (plugs, wires, air filter) has a quadrajunk carb. could it have possibly skipped timing? would it still run with skipped timing?
Old Feb 25, 2006 | 02:03 AM
parks911's Avatar
parks911
Depends on how much it jumped timing.
Turn the distributer while trying to start to see what happens. It can't hurt, the truck isn't running now anyhow.
Old Feb 25, 2006 | 02:20 PM
Bdox's Avatar
Bdox
Pull the plugs and get a reading. If the excess fuel is the problem, the plugs should tell you so. If the plugs are gas fouled, then look for a problem in the carb, like a float that has sunk or a bad needle/seat valve or maybe a blown power valve.
Old Feb 25, 2006 | 03:15 PM
bterry's Avatar
bterry
1. Jack up the air cleaner
2. Push the truck out of the garage
3. Push a Ford under the air cleaner
4. Tighten the air cleaner
5. Fire it up.
Just kidding. No harm done - right.
On a more serious side, you've got plenty of good advise here, make sure you check them all. Also, if none that worked, ensure your timing is close (like the others eluded to). If you've gas, good spark and compression - it WILL fire (providing the timing is close). To get the timing close, make sure #1 cyl is at TDC and the rotor is pointing toward the #1 plug wire. Get it running again, at least crappy, then you can start blaming the carburator.
Old Feb 25, 2006 | 08:52 PM
tomrooster-1's Avatar
tomrooster-1
The idle screws won't stop it from starting. They only effect the idle
Old Feb 25, 2006 | 08:53 PM
Jack-USAF's Avatar
Jack-USAF
well we pulled the plugs and gave them a good cleaning, put them back in and he cranked it as i turned the distributor and she cranked over finally. we are going to get a timing light to get it right but it is running decent for now. thanks for the advice guys.
Old Feb 25, 2006 | 09:16 PM
pfogle's Avatar
pfogle
It sounds like the timing chain is going south. They used a steel gear with fiber or plastic teeth on the cam. I'd replace it as it's cheap insurance.
Old Feb 25, 2006 | 11:18 PM
parks911's Avatar
parks911
Forget about the cheap insurance. If he plans on keeping the truck, invest in a duoble roller with near cam & crank gears.
Old Feb 26, 2006 | 12:12 AM
davethecow's Avatar
davethecow
It sounds like hes got points that are bad.Do you have hei or points type dizzy?
Old Feb 26, 2006 | 05:51 AM
CowboyBilly9Mile
When he get's his hands on a timing light he will be able to get a feel for the condition of that timing chain .
Old Feb 26, 2006 | 10:12 AM
pfogle's Avatar
pfogle
Don't give it the chance to break. That can be a pita. Replace it as it's more than likely the original, and there is probably a missing tooth on the cam gear.
