exhaust
Old Feb 24, 2006 | 07:30 PM
schim34's Avatar
schim34
exhaust
just installed the magnaflow16614 on my 2005 supercrew shortbed 5.4!!nightmare to install,called magnaflow for some tips,told me they don't guarantee it to fit with stock hitch!needless to say,i made it fit,and it sounds awesome!!!!
Old Feb 25, 2006 | 10:34 AM
anollmann's Avatar
anollmann
how did you make it fit? I got one on teh way...
Old Feb 25, 2006 | 03:34 PM
schim34's Avatar
schim34
remove the spare tire,the two brackets that get installed towards the rear need to be installed backwards,and a small bend applied to them,even then you need someone to hold the pipes in place when tightening to keep them positioned were you want them!hope that helps.hope your going to do this on a lift???
Old Feb 25, 2006 | 04:50 PM
anollmann's Avatar
anollmann
I was going to do in on my driveway... sounds like it may not be the best idea. Will the spare tire go back after the install?
Old Feb 25, 2006 | 10:52 PM
schim34's Avatar
schim34
spare tire just clears pipes!!use the lift if possible.real pain in the ***,but well worth it.trucks screams when you wump on it!!!!!!!!!!!!!ps some wires may also need to be pulled away from the pipes on the drivers side.
Old Feb 25, 2006 | 11:14 PM
WhëëlMå1's Avatar
WhëëlMå1
This is definately not the first fitment issue I have heard with the Magnaflow kits. I run a different manufacturer exclusively. I hope future customers stumble upon this, and other fitment issue threads like it.
Old Feb 26, 2006 | 07:33 AM
05 F-150 SCAB's Avatar
05 F-150 SCAB
Speaking of Magnaflow and fitment problems, I just ordered the magnaflow part #16616, wich is the dual exhaust that exits in front of the passenger rear tire, has anyone heard of any types of problems or even anything good about it?
