Fuel Filter Question
Old Feb 24, 2006 | 07:11 PM
MRBASS's Avatar
MRBASS
Getting ready to do the prepump mod and picked up a Mr Gasket clear glass filter with changable element today, Part #9748. There is no info on the package about fuel pressure so I went to their website, mr-gasket.com and there they say this filter is for systems not to exceed 10psi. So how much prepump pressure is there on my 7.3? I'm thinking this filter wont work,,,,or will it?
Old Feb 24, 2006 | 07:21 PM
PSNut's Avatar
PSNut
Pressure? How about vacuum from sucking fuel from the tank. U can install a vacuum guage to monitor your fuel filter cleanliness.
Nut
Old Feb 24, 2006 | 07:31 PM
MRBASS's Avatar
MRBASS
I guess your right,, it would be vacumn.. Still not sure this filter will work and since i am getting ready to go on vacation to colorado and pull my RV and my bass Boat with i sure dont need any fuel pressure problems.
Old Feb 24, 2006 | 07:35 PM
PSNut's Avatar
PSNut
I have a Motorguard inline fuel filter,prepump, that filters down to 1 micron using
a roll of TP. Very effictive filters.
Nut
Old Feb 24, 2006 | 08:19 PM
jtharvey's Avatar
jtharvey
I don't know of any fuel system that runs under 10 psi. Nut's right, that the filter should be installed pre-pump. Check to be sure that the filter is a suction type filter, or it will work in a suction type placement. If it's rated for that, you should be good to go, as long as the flow rates are good enough. I would look for flow rates of 30 GPH. I have a Dalh filter installed and am very happy with it. See my gallery for some pics of it installed.
