Brake warning light
Old Feb 24, 2006 | 11:10 AM
SAlexander's Avatar
SAlexander
Brake warning light
I replaced the master cylinder on my '70 F350 with original power drum brakes. The system is bled and all brakes seem to work well. The brake warning light is still on. I've read that bleeding the brakes should recenter the switch. I guess I need to bleed them more? The rear circuit of the master was the bad one. To recenter the switch, should I continue to bleed the front or rear, or both? Should I just unplug the switch? I need help with this one. I've only had this truck a week so I'm a rookie when it comes to the old ones. This one sure is nicer to work on than my '83 was or my '96 is.
Old Feb 24, 2006 | 12:54 PM
SAlexander's Avatar
SAlexander
I should have followed the guidelines and searched my topic before posting. I found a couple posts. Sorry to waste everybody's time.
Old Feb 25, 2006 | 03:44 AM
jowilker's Avatar
jowilker
Glad we could help.
John
