Problem After Rebuild On A 302
Old Feb 27, 2006 | 01:09 PM
Kemicalburns's Avatar
Kemicalburns
take a broom stick and place it on the lower part of the block. stick your ear to it while the motor is running and move to each cylinder. you should be able to isolate which area is making the noise.
Old Feb 27, 2006 | 01:11 PM
mvvette97's Avatar
mvvette97
Thanks man. I'll try that. It's starting to sound worse.
Old Feb 27, 2006 | 03:10 PM
Kemicalburns
thats not good. i wouldnt run it for to long. if you cant isolate it quickly you may have to pull the pan and check the main bearings for play.
Old Feb 27, 2006 | 06:24 PM
guinness2199's Avatar
guinness2199
slightly bent pushrod?that'll make a racket. and if youve got aluminum valve covers, itll change the pitch of the noise.
Old Feb 27, 2006 | 08:12 PM
mvvette97's Avatar
mvvette97
I'm building a differant engine so I'll just pull that one out then I can tear it down to see what the problem is.
RedDevil460
53
Mar 29, 2014 08:16 PM
lllateralus
Mar 27, 2014 03:28 PM
GBuckert
May 12, 2011 08:30 PM
welfarewagon
Jan 16, 2011 07:11 PM
stellgar
Feb 9, 2002 11:58 PM
