fuel tank swap
Old Feb 23, 2006 | 08:26 PM
rondawgg1118's Avatar
rondawgg1118
fuel tank swap
i have a 86 f-150 2 wd i would like know if a rear fuel tank out of a 93 f-150 2 wd
Old Feb 23, 2006 | 09:56 PM
built 80 f250's Avatar
built 80 f250
um ok i dont under stand BUT if what u meant was can you use a rear tank out of the 93 in and 86 the answer would be maby you would have to use the sending unit out off the 86 in the 93 tank but if the 93 tank is not the same size then no it will not fit
