4.6 ignition miss
Old Feb 23, 2006 | 07:50 PM
pstroker's Avatar
pstroker
4.6 ignition miss
I have a 99 expidition last week the aluminum heater line on the back of the engine decided to spring a leak looks like a weep hole opend up after that repair the moter felt as if it was running on 7 cyl.as suspected some of the water went into the back cyl hole pass side i then pulled the boot and blew all the moisture out still not better so i replaced all the plug wires even thou the ones were in there were less than 10 k miles old still no better any advice will help ...........Marc
