Old Jan 24, 2006 | 07:43 PM
ford390gashog's Avatar
ford390gashog
can you make a 454 ci FE engine with a 428 crank in a 427 block?
https://www.ford-trucks.com/forums/s...49#post3341949
i don't think you can
Old Jan 24, 2006 | 07:55 PM
thunderguns71's Avatar
thunderguns71
Nevermind , isnt there an easy way to makea 454 Ford?
FFR428's Avatar
FFR428
Needsmorecoffee.
Yes you can with a .030 427 block and a 428 crank.....
4.26 x 4.26 x 3.98 x 8 (cyls) x .7854 = 453.82 cu or 454.
G.
Old Jan 24, 2006 | 08:01 PM
thunderguns71
Yup thats it, just as I was using my calculator here , you posted
Old Jan 24, 2006 | 08:14 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Why play with little toy motors, get a 427 bored .020" over to 4.25" and add a 4.25" arm for a 482.3 ci. Now we be talking torque. Step it up with the wallet for a Shelby block bored to 4.40" and add a 4.375" arm for a nice little 532 ci motor. Too rich for me so i'll have to settle for a 482 for the next motor but the 414 keeps running great. Yes the return of the FE's.
.....=o&o>.....
Old Jan 24, 2006 | 08:52 PM
rusty70f100's Avatar
rusty70f100
I like the following combination:
Overbored 360/390 truck block, sonic checked of course, 4.130" bore, 4.25" stroker crank, 462.1 cubic inches
427 blocks are just too darn expensive!
Edit: Although, that FE 454 would PO a lot of chevy guys!
And yes, it's completely possible to build one.
Old Jan 24, 2006 | 10:12 PM
"Beemer Nut"
I want the bigger bore of the 427 motor for more cylinder wall to valve clearance, more inches as well cross bolted bottom end. At the moment i'm watching cash out go because the back injury cost me some time off work the past 9 months. I had one 427 block months ago but it was too far gone and sold it, another ones out there with my name on it. My minds made up, only a 482" will satisfy my motor needs.
.....=o&o>.....
Old Feb 7, 2006 | 01:16 PM
1975Ford's Avatar
1975Ford
Here some additional 427 parts, www.carrollshelbyent.com/ or crate engines http://www.keithcraft.com/our_engines.html and then here the kit cars http://www.factoryfive.com/table/ffrkits/orderakit.html
jake00
Car/truck Buying Advice
Jan 21, 2006 02:54 PM
FE Power
86
Nov 27, 2005 10:53 AM
rywegh
Ohio Chapter
16
Feb 18, 2005 11:09 PM
