won't start
Old Mar 15, 2001 | 10:09 PM
HiMe's Avatar
HiMe
won't start
Old Apr 11, 2001 | 03:04 PM
hoosierman2's Avatar
hoosierman2
won't start
This may sound simple to most of you but .... I turn the key and all I get is a rapid clicking sound from under the hood. I've tapped on the starter but does no good this time. It has never given me a problem till now. I've got a 351M in a 78 F250. I need to get it running soon. Any help would do.
Thanks,
Hoosierman
Old Apr 11, 2001 | 03:09 PM
weldman's Avatar
weldman
won't start
Start with the easiest things!
Check battery....attempt to put a bit of a charge in it if you don't have a tester..see if there is any change.
then solenoid,
then starter
if not any of those which are most common, check the ignition switch.
1978 F250 4x4 - 351M
Build 'em, don't buy 'em!
Old Apr 11, 2001 | 03:29 PM
magnus's Avatar
magnus
won't start
[font size="1" color="#FF0000"]LAST EDITED ON 11-Apr-01 AT 04:30 PM (EST)[/font][p]also, check for corroded/bad battery cables and connections.
i agree with your motto weldman
If you didn't build it, its not really yours.
Old Apr 11, 2001 | 07:47 PM
shortbedford's Avatar
shortbedford
won't start
make sure you check those batt cable ends if it has replacement cable ends also check were the cable is bolted to the cable end more than likley you will find the problem there also check battery itself have it load tested
