Today I got a sheet of 3/16 steel and started replacing a section of my gravel truck box floor. I made some use of the plasma cutter and lots of use on my 7" grinder. Still seeing flashes and feeling hot sparks down my neck.
Maybe you should not use yourself as an integral part of the grounding cable when you weld!!
Haven`t got to the welding part, it`s still plasma cutting and grinding rusty twisted metal.
Where have you been Bouts21, haven`t seen any of your posts for awhile.
