trouble codes TURBO & MORE
Old Feb 22, 2006 | 06:40 PM
wildride454ss's Avatar
wildride454ss
Question trouble codes TURBO & MORE
I Have A Few Codes P0470/p0478/p0500/p0603/p0720/p1247/the Last One Is For The Turbo And Itcame Up As A Turbo Boost Pres Low And Turbo Dont Seem Like It Working I Did Check The Linkage And It Is Hooked Up
And Are Thry Common Code For The 7.3td The Truck Is A F550 Ramp With 240k On It And A Reman Trans With Mybe 20 Miles.
Old Feb 22, 2006 | 09:56 PM
mech2161's Avatar
mech2161
P0470- ebpv sensor circuit, bad sensor, ground circuit or pcm.
P0478- ebp excessive during normal driving
P0500- vss vehicle speed sensor malfunction
P0603- internal control module KAM error, common with a programmer, no problem
P0720- OSS sensor circuit malfunction ??
P1247- turbo boost pressure low Maybe intercooler boot?
I'd clear all and drive for a while and check again
Old Feb 22, 2006 | 10:02 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I haven't looked up all those sensors, but with a new engine I would guess they might all work through a common ground. That's about aall I can think of that could affect the speed sensor, output shaft sensor, and backpressure sensor all at the same time.
