Shifter Arm Bushing
Old Feb 22, 2006 | 04:25 PM
William's Avatar
William
Shifter Arm Bushing
I need a source for the plastic bushing that connects the shift rod with the shift arm at the steering column. I also have a loose special bolt at the shift rod to the short arm from the transmission. I would like to replace the plastic bushing and replace the special bolt if I can locate a source. Any advice is appreciated.
