1978 - 1996 Big Bronco
Broken Fan
Old Feb 22, 2006 | 03:18 PM
wileec's Avatar
wileec
Broken Fan
The fan on my 302 (95) just fell off the other day. Spindle broke at the fan clutch. Question should I go about replacing the spindle clutch assembly or look at converting to an electric set up?
Old Feb 23, 2006 | 07:52 AM
topfisherman's Avatar
topfisherman
I'd go to electric.
Old Feb 23, 2006 | 10:22 AM
BillyBob69's Avatar
BillyBob69
Electric. Better cooling and gives you a couple more horses.
Old Feb 23, 2006 | 11:01 AM
Big Daddy J's Avatar
Big Daddy J
I've pondered doing this myself. What all does it entail? 1 fan...2 fans? Is there a 'complete kit' made for a certain vehicle? (302 automatic with air, tow package, etc...) I tow our pop-up camper a lot in the summer so I got an extreme duty fan clutch...man my Bronco sounds like a school bus now!
Jason
87 XLT 302
Old Feb 23, 2006 | 10:34 PM
topfisherman
Flex-a-lite sells complete kits, but they kind of expensive. If you feel confident in your mechanical ability, you could pick up a taurus fan and put it in your Bronco. If you need the extra cooling, you can fit two on the radiator.
Old Feb 24, 2006 | 07:34 AM
Big Daddy J
I looked at some while at the junkyard last week. I'm just wondering what fans would work and what wouldn't. By that, I mean will it provide enough cooling. I have an old Neon electric fan but I know that wouldn't be enough but I might use that as a second fan next to the primary. Anyone running electric fans...what type do you have?
Old Feb 24, 2006 | 07:37 AM
BillyBob69's Avatar
BillyBob69
Number of fans depends on how big they are. (Who sez size doesn't matter!)
Check the flow rate for whatever you are looking at....the more air it moves, the better the cooling. Electrics are a bit of a pain to put in, but worth it.
Old Feb 24, 2006 | 09:16 AM
TexasGuy001's Avatar
TexasGuy001
As far as fans go, I don't trust the electric fan setups. I have had them fail and/or have intermittent problems on 2 different cars we have had, as well as seen the problems on several of my friends cars when they get a few years old. My truck did that when I replaced the fan clutch too.
Old Feb 24, 2006 | 10:40 AM
Big Daddy J
So, would the Black Magic 15" Electric Puller Fan alone be enough? It's rated at 2800 CFM. I have no clue what the cfm's are of the factory pulley mounted fan, which I guess depends on the clutch, to compare when looking at electrics.
Old Feb 25, 2006 | 07:41 AM
BigRedBronc's Avatar
BigRedBronc
2800 is not enough to keep your Big Bronco cool. I installed Flexalite twin fan setup on BigRed and absolutely love the results. Check the website for more data.
Old Feb 26, 2006 | 07:50 AM
Big Daddy J
Thanks for the info BigRed! Looks like I'll be ordering myself a Flexalite kit!
Thanks again,
Jason
87 XLT
