Possible lower turbo pedestal leak - how long until it's worse?
I recently had my turbo out to install the WW. After I got it all back together it was leaking from what looked like the o-rings. I figured I must have messed that up somehow. Had puddles in the valley and running down back of the engine. All the other common places for leaks up on top were ruled out, so I was looking froward to pulling the turbo again this weekend and doing the o-rings again. # days ago I got down in there and cleaned all the oil up figuring I might actually be able to see where the leak was coming from... now.... no more leak! Been running it for 3 days and checking it a few times a fay and nothing. Anyone ever hear of these things 'magically' stopping?
Originally Posted by GoCamping
Do you have any hints for getting a better look at the lower pedestal connection? Does a mirror help?
Originally Posted by jtharvey
My guess is a couple of things could have happened. One, the o-rings swelled slightly due to oil exposure and heat causing them to seal. Or two, one of the o-rings was just a hair out of place, but the heat & pressure of the oil caused it to pop back into place. Keep your eye on it though.
