Painting Plastic
Old Feb 22, 2006 | 01:36 PM
02superstroker's Avatar
02superstroker
Painting Plastic
I have a kayak that I am wanting to paint, but am wondering if there is any kind of paint at all that will stick to plastic. thanks
Old Feb 22, 2006 | 01:41 PM
SuperSnake's Avatar
SuperSnake
Krylon has a paint called fusion made just for plastic.I have seen it at Napa and Walmart.
Old Feb 22, 2006 | 03:16 PM
RocketScience's Avatar
RocketScience
Bulldog Adhesion Promoter will allow most paints to stick to plastics.
Old Feb 22, 2006 | 04:53 PM
02superstroker
thanks guys...
Hey old tired... have you used the krylon fusion? any good, durable?
I appreciate it
Old Feb 22, 2006 | 05:31 PM
jroehl's Avatar
jroehl
We used some Fusion to paint some receptacles in a custom home once. After a few hours it seemed like it was tough as nails--it didn't scratch off with my fingernail very easily. BUT, a few days later it scratched off quite easily.
You're probably just as well sanding first with 180-220 grit (nothing finer) to give it some "tooth". THEN go for some sort of bonding primer--go to a paint store that serves contractors (such as Sherwin-Williams, PPG, ICI/Glidden, etc.) and tell them what you are trying to do. They should be able to steer you in the right direction. It could help if you know the exact "plastic" of which your kayak is made. There are many, many different types of plastic.
Jason (a pro painter)
Old Feb 22, 2006 | 06:07 PM
Mil1ion's Avatar
Mil1ion
Have you considered Marine paint ?
Old Feb 22, 2006 | 06:55 PM
Snake1979's Avatar
Snake1979
I'm not sure about Marine parts like a Kayak but,
When I worked for my dad, We used plastic prep from 3M after we sanded the plastic parts for cars. Like I said, I'm not sure how that would go with full on all water contact, but I'm sure its similar. We then coated it with Variprime, and then Uroprimer, sand that down slightly, then paint.
Old Feb 22, 2006 | 10:55 PM
02superstroker
Thank you all for the suggestions... in case it helps, i don't know if this is the type of plastic or what, but they say it is a polyethylene boat
thanks again
Old Feb 22, 2006 | 10:57 PM
e1p1's Avatar
e1p1
Go to a Marine (no, not the USMC) store or visit www.westmarine.com and look up info on boat paint, or even colored gelcoat. Try the product advice link.
A decent topsides paint will be durable and a bit flexible, and when combined with the stuff they recommend for getting the paint to smooth out (and applied with a quality fine brush) you can't tell it from spray-on unless you get yur eyeball right on it.
Old Feb 23, 2006 | 05:52 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
A guy down the street from me is (was) a painter. His house was an almond vinyl siding. He cleaned the siding, then sprayed some sort of 'primer' on it, then painted it white.
That was 15 years ago, and he has moved since then.
The house still looks great! It has not been repainted, either.
With that said, you might want to check with a paint store, i.e. Duron, Sherwin-Williams, McCormack, etc. (Not a place like Lowe's or Home Depot.)
Just a thought. . .
Old Feb 23, 2006 | 11:25 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Sounds like a roto mold poly yak which has alot of flex and oil base. Try a test spot inside but first wipe down with lacquer. There was a additive for paint before spraying on plyable airdams which prevented cracking. Check with a good marine supply. I have a Necky Arluk 3 in kevlar but then that's a hard shell, S.F. bays my playground.
.....=o&o>.....
Old Feb 23, 2006 | 11:32 AM
00BlueOvalRanger
.....=o&o>.....
Beemer. . . .
Sounds like a 'what'????? You lost me on that word "roto." The rest of it has me moving my index finger up and down on my lips, mumbling, "Buh . . . buh. . .buh. . .buh. . .buh. . .bub."
Old Feb 23, 2006 | 12:25 PM
"Beemer Nut"
Where they pore liquid plastic in a mold and rotate the mold until it cures to prevent a thick puddle on the bottom, even thickness thru out the hull.
I see your not a kayaker or been following their progress the past 20 years.
.....=o&o>.....
Old Feb 23, 2006 | 01:05 PM
00BlueOvalRanger
.....=o&o>.....
Kayaks? Nah. The only way I could even spell it was to look up and see how you spelled it! (J/K.)
Sounds pretty 'slick' the way you describe it.
Thanks.
Old Feb 23, 2006 | 01:33 PM
Encho's Avatar
Encho
The Southernmost Mod
thanks again
Who says? if it´s the manufacturer then that is the type of plastic.
