Chapter Leader Chat
Old Feb 24, 2006 | 01:14 AM
  #31
jd_sylvia's Avatar
jd_sylvia
Ok I will try for sunday..
Got a call from work had to walk them thru a puter problem at 11: pm.
jd
Old Feb 24, 2006 | 03:02 AM
  #32
ZombieSlayer's Avatar
ZombieSlayer
I won't use the crappy chat client here. But I can explain how to create a seperate channel for you folks to use.
Enter the main chat room and type
.cFTE NorCal and then enter (or click submit whichever one works, note the period before the c if it's not there it won't work)
That should give you your own channel to chat in.
Old Feb 24, 2006 | 03:04 AM
  #33
ford390gashog's Avatar
ford390gashog
awesome thanks for the info!
Old Feb 24, 2006 | 03:09 AM
  #34
ford390gashog
i just tried and it won't work. it rejects all the .c commands.
Old Feb 24, 2006 | 03:12 AM
  #35
WillyB's Avatar
WillyB
Yea, the guys up there earilier said the rooms had been shut off - only the main (home) one worked.
Old Feb 24, 2006 | 03:14 AM
  #36
ford390gashog
i just got removed from the chat room for spam! no one was there so i though i would try out the features and i was removed for spam.
Old Feb 24, 2006 | 09:32 AM
  #37
olfordsnstone's Avatar
olfordsnstone
Could we use the chapter forum in the same way as chat room? Well, as long as it is done with a little organization maybe?
Sunday I'll be at work, however I will be able to get away for the meet if times are appropriate.
Old Feb 24, 2006 | 09:12 PM
  #38
Sonoragoose's Avatar
Sonoragoose
I was going to suggest the same thing, this forum is fast enough for a meeting. If you plan to have it Sunday night I'll try to make it. What time?
Old Feb 24, 2006 | 09:50 PM
  #39
jd_sylvia's Avatar
jd_sylvia
Sunday works for me, I'll be up at Pardee Saturday seeing if I can get some fish in the boat.
jd
Old Feb 24, 2006 | 10:05 PM
  #40
WillyB's Avatar
WillyB
I have Yahoo messenger - does anyone else? I would load MS messenger if it would help. both services let multi-parties talk to each other.
My user name on Yahoo is clintwilcox should you want to try to contact me using Yahoo messenger
Old Feb 24, 2006 | 10:09 PM
  #41
jd_sylvia's Avatar
jd_sylvia
I use MSN messenger..
jd
Old Feb 24, 2006 | 10:14 PM
  #42
olfordsnstone
At my work, which is where I will be on Sunday, I cant load anything. Damned firewalls. I'm stuck with this forum. Oh well, post the communication method and I will attend if I can. If not, at least post the meeting minutes.
Thanks,
Old Feb 24, 2006 | 10:26 PM
  #43
WillyB's Avatar
WillyB
Tim, don't give up on us yet - we are just looking to see what is possible.
Old Feb 24, 2006 | 10:45 PM
  #44
ZombieSlayer
Ok I set up a temporary chat program on my site we can use.
http://www.thunder65.com/temp/ftechatroom.html
I'm there now if someone wants to join to help make sure it's working.
It requires Java and active X (set browser security to medium if it doesn't work when you first get there).
Old Feb 24, 2006 | 10:54 PM
  #45
WillyB's Avatar
WillyB
ZombieSlayer's chat room works for me - looks like we have a solution! Can anyone else sign on so we can see how many users it can handle?
