fuel question
Old Feb 21, 2006 | 10:26 PM
BigBlue93's Avatar
BigBlue93
fuel question
7.3L non-turbo -- If I run out of fuel can I switch tanks and keep going like on a gas engine?
Old Feb 21, 2006 | 10:36 PM
flatbedjeff's Avatar
flatbedjeff
iF THE ENGINE DIES YOU MAY HAVE TO CRANK IT SOME TO GET FUEL UP, BUT YOU SHOULD BE ABLE TO JUST SWITCH EM NO SWEAT..
Old Feb 21, 2006 | 10:42 PM
PLC7.3's Avatar
PLC7.3
Try not to run the tank dry....the lack of fuel can hurt your IP as it is used as a coolant and lubricant.
If it does run dry and stall, bleeding at the filter head Schrader valve while cranking the starter is required until all air is gone. Starter cranking is limited to 15 seconds per time with 2-5 minutes cool down.
Old Feb 22, 2006 | 07:00 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome BigBlue to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 22, 2006 | 04:12 PM
dieself250's Avatar
dieself250
At freezing tempatures you dont want to run the tanks below 1/4 tank
