chassis flex
Old Feb 21, 2006 | 10:24 PM
trkrunner's Avatar
trkrunner
chassis flex
Hello folks! I have an 82' F100 with a 4.9L and a 4spd T18 gear box. Everytime I push on the clutch pedal the chassis will flex where the equalizer bar bolts to the chassis. Any ideas on how this problem can be fixed. Thx Trkrunner
Old Feb 22, 2006 | 04:12 AM
8 Lugs's Avatar
8 Lugs
Is the truck's frame actually flexing from clutch movement? Is the frame cracked in the area?
This would require welding and possibly re-enforcement to repair.
Or are the rubber cab mounts shot allowing the cab to pull closer to the frame when the clutch is depressed?
Could the floor be rusted out or cracked around the cab mount bracing and not properly supporting the cab anymore?
Take a second look and let us know.
Steve G.
Old Feb 22, 2006 | 05:37 AM
Dungeon_Master's Avatar
Dungeon_Master
rusted out cab corners could help contribute to the flex also.making it seem like the frame is flexing when it is the cab flexing.
Old Feb 22, 2006 | 11:09 AM
trkrunner's Avatar
trkrunner
Cab mounts are in good shape. Imay end replacing the rubber with polyeurathane. Thx for the reply-Trkrunner
