230 volt compressors
AK Ford
>answer that I was looking for: is it better to buy a 230
>volt compressor as compared to a 115? I understand the amp
>draw is lower on the 230 volt for the equivalent HP motor.
>I already know that I want an iron,belt driven, two stage,
>oil usin' compressor but I don't know if I need a 230 volt
>or not. It seems like a pain in the butt to wire in a 230
>outlet to my fuse panel, but maybe not???
You must not have searched very hard... There is lots of info here. There are only four pages and you can search them with your eyeballs also. There is a direct answer for your question in the following topic:
https://www.ford-trucks.com/dcforum/DCForumID75/259.html
There are links there that will take you top many other relevant topics etc.
>The only
>"quality" compressors in this area are Emglos or Ingersol
>Rands, otherwise it is a Sears (I think they just rebrand
>Campbell Hausfelds) but the local Sears tools manager pissed
>me off so I don't want to buy from them, a childish
>attitude, I know.
It is not childish, it is the only way a consumer has to "punish" or fight back against a store chain for hiring idiots for employees, or having bad store policies. I havent shopped at Sears for 20 years due to some idiotic policies. I havent shopped at Wards for almost as many and now they are gone, Sears is dying. I guess enough other people didn't like their policies either. My father was a retailer and he always tought me the customer is always "right". Of course he is out of business now too. The trick is compromise and negotiation.
>Anyway, 230 or 115 volt?
230V
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Like I said... Go 230V.
Those are what we call Cheater motors. They use rotor lock amps to calculate HP rather then actually dyno specs. In essence a 3450 5HP motor is only equivilent to a 2.5-3 HP 1728 RPM dyno tested motor.
Another clue if the unit is a cheater unit is the CFM (cubic feet per min) output rating.
As an example, Any decent 5HP pump will put out 18 CFM or more At 100PSI. The '@100PSI' rating is important, as pressure increases the pumps ability to produce flow decreases, as pressure decreases the pump can produce more flow. When shopping you will see specs like 5HP 25cfm @40psi, laugh and walk away, cause at 100psi this unit might produce 12cfm of air flow no where near what a 'real' 5hp can put out. If you plan on using tools like a die grinder or a 1/2 impact gun a true 3HP 12CFM@100PSI unit will just keep up to light use. If you plan on heavy tool useage or doing body work then opt for a real 5HP or better unit.
Hope this helps you make a more informed purchase.
Tom.
I go out to look thinking this is going to be a waste of time. The whole if he is getting rid of it thing. Well looked at it thought no biggie. Guy didn't even know if it would work or not. so we took it to his shop and him and my dad start running wire to hook it up. I am think what the HECK??? Well come to find out it is a 230 volt high duty rated compressor with a little ole 20 gallon tank. I get to talking to Carroll(my Dads friend), by the way he is one heck of a body man, he has used it to do countless #'s of car bodies running DA's, Body Files, Die grinders, etc. all with never having to wait for the pressure to build back up. By this point I am hooked. Ask him how much? After we found out it was working. He tells me $50.00. I say sold. I had to get a few thing for it, and it has a few leaks I need to run down. But all in all It is a great compressor. All the other stuff I bought for it I would have had to buy for a new one also so I got a really good deal in my opinion.
I have spent a total of $90 so far on it. $20 of which could have been saved if I had waited and went to Wal-Mart instead of ACE hardware. But, I am still happy with waht I got.
My whole point to this is Look around someone knows someone with one they just don't know it yet.
Scotty
With air compressors, bigger is better. I've got a 6.5hp, 80 gal, 17 cfm@175psi compressor and it's great. You definatly get what you pay for when you buy a compressor.
