1983 6.9liter
Old Feb 21, 2006 | 08:53 PM
6.9FordMan's Avatar
6.9FordMan
1983 6.9liter
Ok, I replaced my starter and my I.P. I BLED THE FUEL LINES!
And my truck STILL will not start. I DON'T KNOW WHY?!??!?!?!
before you ask question read this.
-BOTH BATTS ARE BRAND NEW AND CHARGED FULLY
-TERMINALS ARE BRAND NEW
-THE COMPLETE GLOWPLUG SYSTEM IS NEW AND IS WORKING
-ALL THE ELECTRICAL SYSTEM IS WORKING
Old Feb 21, 2006 | 09:31 PM
6.9FordMan's Avatar
6.9FordMan
ALSO.....
long-story-short.... Replaced Alternator, then voltage regulator went out causing everything in the electrical system to be fried. Replaced everything in the electrical system (EVERY THING WORKS NOW).-still no start-found out the shut-off solenoid went out. So I replaced the IP. Stater went out when bleedinf fuel lines, so I replaced the stater.
Don't tell me it a fuse, relay, or fusable link. ALL of them have been replaced. AND TESTED!!!!!!!!!
It also WILL NOT start on starting fluid or WD40.
I was driving down the highway AT NIGHT when the voltage regulator went out- causing every light to go out. I took the next exit, 800 feet away, and the engine died on the off ramp. NEVER TO START AGAIN.
Old Feb 21, 2006 | 09:46 PM
6.9FordMan's Avatar
6.9FordMan
PLEASE READ MY POST THROUGHLY, I GET ALOT OF THE SAME QUESTIONS OVER AND OVER AGAIN!!!!!!!!
Old Feb 21, 2006 | 10:47 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Where are you located?
I sent you a private message with my phone number.
