Sponsored by: Real Truck
healight switch removal
Old Feb 21, 2006 | 05:46 PM
Ford Truck Racer's Avatar
Ford Truck Racer
What is the procedure for removing the headlight switch on a 99 f-250. I did a search and can't find what I'm looking for.
Old Feb 21, 2006 | 05:54 PM
turbostroke's Avatar
turbostroke
I have a 99.5. It's a tricky little deal... It can be done, but if you pry the faceplate too far you will break the connectors off the back that hold it on. Here goes... there are 3 "connectors" on the switch, 2 on the top and one on the bottom. They are all tied in together with the same piece of plastic. In the fully closed position (as it is on your dash now) these three tabs are fully extended to the left (drivers door) you need to pry the faceplate at the top or bottom and push one (only one necessary as they are all tied together) to the right (towards passenger door), as you go to the right this allows the three tabs to line up with three square notches in your dash panel allowing you to pull the whole assembly out (towards the back window). Sounds complicated but really isn't as this will make complete sense once you have it out and can see the back of the switch for yourself. Just be extra careful as this is not a cheap part to replace! If you pry the top of the faceplate you will find 2 connectors about an inch apart or keep it simple and pry the bottom of the faceplate and a single connector is in the center of the faceplate.
Old Feb 21, 2006 | 05:55 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
it should be in some of the gauge installation instructions on various Diesel retailers- most recommend tapping the dimmer wire at the switch.
when i removed mine, i just took a wide bladed,slotted screwdriver (flat) and pry between the dash and the housing on the switch. slight twisting motion. once on the left and once on the right and it will pull out relatively easy. there is two hookups in the rear, one for the selector ****, and one for the dimmer.
after searching, i found this. don't pay attention to the arrow, it pertains to the gauge install. if im thinking correctly, you want to pull this whole unit out, and not just the ****?
Old Feb 21, 2006 | 06:09 PM
turbostroke
Ford truck racer you asked about a 99 switch. DO NOT use the screwdriver attempt on our year truck or you will be buying a new switch. Believe me the back of our switch does not look like that one in the picture above. I think they changed when they started adding factory fog lights.
Old Feb 21, 2006 | 06:36 PM
Kwikkordead's Avatar
Kwikkordead
My truck is a '99. Pictures in the next post.
Old Feb 21, 2006 | 06:54 PM
Kwikkordead
Except for what turbostroke said.
Ok pictures tell it better than a lot of words.
The third picture my finger is pointing to one of the three release tabs. The other two are on the top. Don't pull it all the way to the right, there is a little slot in the facade that the tab needs to come out through. Get it lined up just right and the switch literally falls out of the hole.
The last picture shows the lock tooth. It's just like a standard door latch in your house.
Hope this helps.
Old Feb 21, 2006 | 07:01 PM
turbostroke
Thumbs up
Thanks KWIK for the pics - If you haven't done it before it does get tricky to explain.
Old Feb 21, 2006 | 07:27 PM
Kwikkordead
I just discovered that the little spring came loose inside. I took the switch apart and reset it. Now think that it would be a lot easier to try and push on the little tab that is on top of the switch right next to the locking tooth. Try and push on the bottom one and it will just bend the linkage inside. You can see the tabs in the last picture, kinda fuzzy but they are sticking up at the end of the angled slots.
Old Feb 21, 2006 | 07:38 PM
turbostroke
The blue arrows below indicate the tabs that need to slide to the right before switch housing can be removed from dash panel....This should explain it
Old Feb 21, 2006 | 09:12 PM
Ford Truck Racer
Thanks, I went to install my guages today and could not get the light switch out. Appreciate the pictures.
Old Feb 21, 2006 | 09:26 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Lots of good pictures. A well documented procedure.
Thread moved to proper forum.
Old Feb 22, 2006 | 06:40 PM
Ford Truck Racer
Got my guages mounted, just wondering is there a hole already in the firewall to feed the wires through or will I have to drill one?
