Trouble in my head
1) If you just want to get it running & aren't too fussy, use the 272 head (assuming it's in good shape, of course). Not my choice to use different heads, but it's been done before. Note that for your two engines this is possible, but in other cases it may not be (for example, a Boss 302 head won't go on, say, a 221 small block Ford; it will physically bolt on, but the larger valves would hit the block.)
2) On the other hand, from an engine builder's point of view, it's best to make each cylinder's output as close to the others as possible, both for power & efficiency. There are a great many techniques & philosophies on how to do this, but, obviously, you would use the same size parts in each.
3) So far as power/mileage, you may not notice a whole lot either way. Tough to say.
4) As long as you are going to this amount of work, it might be worthwhile to take BOTH the 272 heads, freshen them, and use that pair. Assuming you don't want to do that/can't, then I'd get the other head with the smaller valves, if it is similar to your existing 292 head- there are three different intake valve sizes, & a lot of different castings.
5) Depending on what pieces you have, you might possibly have some issues with port matching. Keep an eye out so you don't end up with a vacuum leak.
Clear as mud?
Like him I'm not necessarily suggesting you use two different heads, but if you did, chances are you wouldnt notice it if the truck is used as it was intended.
The imbalance between different spec heads wont be that noticable on a stock street driven truck; heck even Ford was sloppy on their chamber tolerances on any one head.
How about posting some casting ID's?
Is there a majior fuel consumption difference? Which heads are you running?
Thanks for all the help it is greatly appreciated.
