Overdrive Not turning OFF (not blinking - shifting fine)
I tried searching for this topic - but all that kept coming up was Overdrive BLINKING light threads.
I just got this 1997 Eddie Bauer back in December 2005 with 73,000 miles.
Runs great - did have to clean the MAF sensors - but no issues with it until now.
When I got it the OD On/Off button on the end of the shift lever worked fine. It would turn off the OD and the RPMS would raise up.
Recently I tried turning the OD off. The light should come on, and the RPMS should go up; I get neither.
Is there something simple to check on this?
The truck shifts fine, runs fine, no shudder, no blinking OD OFF light.
https://www.ford-trucks.com/forums/s...=OD+off+button
Ok I found one thread...
I just remembered I will need to check my connections under the steering column shroud since I just added a remote starter to the Exp and had to put the transponder key sensor around the ignition barrel - so I had the colum cover off - might have knocked something loose - I'll check that.
