Got two more gauges to hook up?
I found a plug on the water pump just to the right of the factory one so I'm good there.
I read somewhere on this site that there is a plug on top of the oil filter housing that will work and there is also a plug on the top of the HPOP that would give a more accurate reading but it takes some sort of special adapter fitting to make it work there.
Anyone know anything about that fitting or should I just go with the filter plug.
Thanks in Advance
Thanks in Advance
Nut
