05 SD tow command
Hope These Help
Gunner15a
Here's the latest SSMs related to the Tow Command system.
18630 2005 SUPER DUTY F-SERIES - NORMAL OUTPUT VOLTAGE FOR A MANUAL APPLY FROM THE FORD TRAILER BRAKE CONTROLLER - SERVICE TIP
THE VOLTAGE OUTPUT FOR MANUAL TRAILER BRAKE APPLICATION FROM THE FACTORY INSTALLED TRAILER BRAKE CONTROLLER ON 2005 F-SUPER DUTY VEHICLES IS IN TWO DIFFERENT RANGES, BASED ON BUILD DATE. THE NORMAL OUTPUT VOLTAGE FOR A FULL MANUAL APPLY (MANUAL ACTIVATOR LEVER SLID FULLY TO THE LEFT, GAIN SETTING OF 10, VEHICLE NOT MOVING) IS 1-3 VOLTS ON VEHICLES BUILT BEFORE 3/23/05, AND IS GREATER THAN 10 VOLTS ON VEHICLES BUILT AFTER 3/23/05. BRAKE PEDAL BASED OUTPUT FROM THE CONTROLLER IS THE SAME REGARDLESS OF BUILD DATE. DO NOT REPLACE THE CONTROLLER IF IT IS PROVIDING VOLTAGE OUTPUT IN THE CORRECT RANGE BASED ON BUILD DATE. REFER TO SECTION 206-10 OF THE WORKSHOP MANUAL FOR FURTHER INFORMATION.
EFFECTIVE DATE: 05/26/2005
18531 2005 F-SUPER DUTY - KIT AVAILABLE FOR DEALER INSTALLATION OF TOWCOMMAND SYSTEM
TO INSTALL A TRAILER BRAKE CONTROLLER ON A 2005 F-SUPER DUTY THAT WAS NOT ORIGINALLY EQUIPPED FROM THE FACTORY, ORDER KIT 5C3Z-19H332-AA FOR ALL GAS ENGINE SINGLE REAR WHEEL APPLICATIONS; OR ORDER KIT 5C3Z-19H332-BA FOR ALL DIESEL ENGINE AND DUAL REAR WHEEL APPLICATIONS. FOLLOW THE INSTALLATION PROCEDURES IN THE INSTRUCTION SHEET INCLUDED IN THE KIT. REFERENCE SECTION 206-10 OF THE 2005 WORKSHOP MANUAL FOR ADDITIONAL INFORMATION IF NEEDED.
EFFECTIVE DATE: 04/07/2005
18472 2005 F-SUPER DUTY - DEALER INSTALLATION OF TOWCOMMAND SYSTEM - SERVICE TIP
IF A TOWCOMMAND SYSTEM TRAILER BRAKE CONTROLLER IS DEALER-INSTALLED ON A 2005 F-SUPER DUTY THAT DID NOT COME FROM THE FACTORY WITH THE TOWCOMMAND SYSTEM, THE CONTROLLER MAY NOT OPERATE AND FUNCTION AS DESIGNED UNLESS A BRAKE PRESSURE TRANSDUCER EQUIPPED MASTER CYLINDER IS INSTALLED AND THE INSTRUMENT CLUSTER IS RECONFIGURED. TO CONFIGURE THE CLUSTER USING WDS (CANNOT USE NGS): IDENTIFY VEHICLE; SELECT TOOLBOX ICON; FROM LIST ON LEFT SIDE OF SCREEN SELECT 'MODULE PROGRAMMING' AND HIT TICK BUTTON; SELECT THE PROGRAMMABLE PARAMETER ITEM AND A SUB-MENU WILL APPEAR. IN THIS SUB-MENU, SELECT 'PERSONALITY' AND HIT TICK BUTTON; SELECT 'TRAILER BRAKE CONTROLLER' THEN SELECT 'EQUIPPED'. MASTER CYLINDER INSTALLATION AND CLUSTER RECONFIGURATION TO COMPLETE DEALER-INSTALLATION OF THE TOWCOMMAND SYSTEM ARE NOT WARRANTABLE.
EFFECTIVE DATE: 03/15/2005
18253 2005 SUPER DUTY F-SERIES - AFTERMARKET TRAILER BRAKE CONTROLLER INSTALLATION - SERVICE TIP
THE CONNECTION POINTS FOR AN AFTERMARKET TRAILER BRAKE SYSTEM ON A 2005 SUPER DUTY F-SERIES ARE THE SAME AS PRIOR MODEL YEARS. THE AFTERMARKET TRAILER BRAKE CONNECTOR (VEHICLE SIDE) IS MOUNTED TO THE BACK OF THE STORAGE BIN TO THE RIGHT OF THE STEERING COLUMN BELOW THE RADIO. THE LOWER PANEL BELOW THE RADIO MAY NEED TO BE REMOVED TO GAIN ACCESS TO THE CONNECTOR. THE BLUNT CUT HARNESS (BRAKE CONTROLLER SIDE) IS LOCATED IN THE GLOVE BOX. IF A CUSTOMER WANTS TO INSTALL AN AFTERMARKET TRAILER BRAKE CONTROLLER ON A VEHICLE EQUIPPED WITH A FACTORY INSTALLED CONTROLLER, THE FACTORY INSTALLED CONTROLLER MUST BE LEFT INTACT AND THE AFTERMARKET CONTROLLER INSTALLED COMPLETELY SEPARATELY. FOR ADDITIONAL INFORMATION, REFERENCE WORKSHOP MANUAL SECTION 206-10.
EFFECTIVE DATE: 10/21/2004
