gas mileage help
Old Feb 21, 2006 | 09:07 AM
videoman40's Avatar
videoman40
gas mileage help
Hi everyone,
I have a 1982 ford van, with low mileage, about 66k on her. It has the 300CID six cylinder engine. I don't go anywhere in a hurry, and speed is not a concern, gas mileage is though. I drive her alot, and the cost of gas kills me, can you give me any advice on how to improve mileage please?
Dominic
Old Feb 21, 2006 | 12:25 PM
srercrcr's Avatar
srercrcr
Keep the tires pumped up.....reduces rolling resistance.
Remove unnecessary weight in the van....why lug it around?
Drive like you're not in a hurry to get there.
Consolidate trips.
If a std tranny, shift sooner....rpms = gas burned.
Reduce sitting idling/warming up....hit the road, jack!
Keep the engine tuned up and make sure each wheel turns freely (dragging brakes).
That's a good start.
Old Feb 21, 2006 | 12:48 PM
quicklook2's Avatar
quicklook2
change plugs if more than a year old, change air filter even if it is only a little dirty.
you are driving a brick down the road and it will never get real good mileage.
check engine with a vacuum gauge, it will tell if engine is running efficiently.
Old Feb 21, 2006 | 08:28 PM
VikingBabe's Avatar
VikingBabe
I drive an 81 E100 two seater former water delivery van with dual gas tanks. Got it early last year and was completely empty as the owner took all shelves out before putting up for sale. It is insulated with foam though. But had to fix the rear brakes before driving it and replaced all tires with new ones. Makes a big difference.
Another suggestion is to drive with the windows up. The airflow acts like a "drogue" sail and it actually takes more gas to keep the same speed. That also helped increase my mileage.
oddjob75150
6.2L V8
99
Feb 24, 2022 04:33 PM
keyston44
2009 - 2014 F150
15
Mar 10, 2014 09:00 PM
fordsrbetr
Nov 11, 2006 09:10 AM
reddog99
1983 - 2012 Ranger & B-Series
Apr 18, 2006 06:52 PM
01f350
Dec 20, 2005 07:43 PM
