302\351
Old Feb 21, 2006 | 08:32 AM
dv_shane's Avatar
dv_shane
302\351
i want to build a clevelor motor can anyone help me out?
i have a set of cleveland 2v heads with 4 v valves in them i left the intake ports
as they were so i can get some low end power out of them. and i bought a none roller 302 that is bored 0.40 over with 5.000 miles on it from a wrecked truck.
now i know that the heads need to be drilled in a couple places and block off 2 places too.and the block needs to be drilled too. but what i need to find out is can i buy a set of 351 pistons 0.40 over and use them? due to the canted valves in the 351 heads. and the heads i have are D1AE CB open chamber if the 351 piston idea will work what compression would i need to buy to end up with
10 or 10.5 to 1 any help would be helpfull thanks dave
Old Feb 21, 2006 | 06:17 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
