Broken Motor Mount?
Old Feb 20, 2006 | 09:40 PM
mdjohnson's Avatar
mdjohnson
Question Broken Motor Mount?
Lately I've noticed a clunk sound when taking off from 1st gear. Today I went into Advance Auto parts and they had one of those car care videos playing and it was talking about bad motor mount problems. It fit the description, also the shifter moves more then it use to when shifting. So, could it be a motor mount? How much do shops charge to change them?
Thanks.
Old Feb 20, 2006 | 10:14 PM
brosko80's Avatar
brosko80
dont know always changed em myself. unbolt, jack up motor, replace mounts
Old Feb 20, 2006 | 10:22 PM
mdjohnson's Avatar
mdjohnson
What about solid motor mounts? Are they better?
Old Feb 20, 2006 | 10:49 PM
lv2race's Avatar
lv2race
Pop your hood, start engine, step on the gas and watch for your engine to jump. If engine jumps, you have a broke mount.
If you like a smooth quiet ride, don't go to a solid mount.
Old Feb 20, 2006 | 10:52 PM
mdjohnson's Avatar
mdjohnson
Yeah, the engine move quiet a bit. Will a solid mount cause any problems down the road? I'm really not conserned about a smooth quiet ride.
Old Feb 20, 2006 | 11:03 PM
brosko80's Avatar
brosko80
puts more stress on the rest of the driveline. the motor has to have a little flex. to see if the mounts are bad, put it in gear hold the brake on and give it a little gas. that will put all the stress on the motor sincu the truck cant move foward withe brakes on and tell you if the motor mountd are seperating. a little movement is ok but have someone look at the mounts as you do this to see if there is any exessive movement and if the mounts are seperating.
Old Feb 20, 2006 | 11:18 PM
mdjohnson's Avatar
mdjohnson
I have a 5 speed I can't do that, but I can put it into one hell of a power brake. I think I'll just get regular mounts.
Old Feb 21, 2006 | 08:09 PM
brosko80's Avatar
brosko80
with a 5 speed just use the e brake, same thing.
