Back up Neutral Switch Adjustment?
Old Feb 20, 2006 | 06:00 PM
tractoman's Avatar
tractoman
I need to adjust the switch on the column to operate the back up lights. If I move the switch with my finger all the way to the drivers side, the back up lights will come on. With the switch adjusted this far over, I will not be able to get it over to park. Are there any instructions or diagram of how this should be adjusted? This is a '76 F250 Super Cab w/ 460 and C6.
Thanks,
Mike
Old Feb 20, 2006 | 06:27 PM
LxMan1's Avatar
LxMan1
Sounds like the switch may be bad. They shouldn't come on all of the way over. It should let the engine crank in that position.
Old Feb 20, 2006 | 06:47 PM
MBBFord's Avatar
MBBFord
It may just need to be readjusted. There is a small hole in the switch that you need to put a small drill bit in and do somthing or another to fix it. If you have a haynes or chiltons repair manuel, it would tell you how to adjust it. If not, wait alittle while and get Mil1ion to tell you how, he's the one that told me.
Old Feb 20, 2006 | 08:12 PM
Mil1ion's Avatar
Mil1ion
The guys could have sent you to my gallery.
Loosen NSS on column
Put Trans in Neutral
Put Gear shift in Neutral
Adjust switch so drill bit fits through to other side of switch. Tighten bolts on NSS
Old Feb 20, 2006 | 08:31 PM
MBBFord's Avatar
MBBFord
So Mil1ion, your saying, just loosen the bolts holding the NSS on the colum, then move the switch till the drill bit goes completly through, then leave it there while you tighten the bolts back?
I riged mine to work for start up, but my reverse lights still don't work.
Old Feb 20, 2006 | 08:52 PM
Mil1ion's Avatar
Mil1ion
Then it could be a ground problem for the lights or the switch needs cleaning.
