Bronco II Ford Bronco II
Parking Brake Problems
Old Feb 20, 2006 | 12:48 PM
Aces_&_Eights's Avatar
Aces_&_Eights
I just bought a 1988 Bronco II. I am having a problem with the parking brake. The brake works, as in it will stop and hold the truck, but it will not lock in the down position when I try to set it. Does any one have an idea what I woud need to replace? Thanks for your help.
Old Feb 20, 2006 | 03:39 PM
broncobillyII86's Avatar
broncobillyII86
I think there is some kinda linkage there like a gearing that holds it there it must be slipping off the gearing or the gearing lets go so the pedal comes back ....Not sure, maybe take a look under there and see what you see when it is engaging ...TR
Old Feb 22, 2006 | 11:11 AM
kernel-panic's Avatar
kernel-panic
Sounds like the spring that ratchets the lock isn't working (weak or busted?). You'll probably have to unbolt and remove the parking brake assembly and take a look at what's going on.
Old Feb 22, 2006 | 11:43 AM
Monty06's Avatar
Monty06
sounds like you need a brake kit and while you at it change out shoes.
