Cab Mounts
Old Feb 20, 2006 | 11:48 AM
WOFP's Avatar
WOFP
Question Cab Mounts
I Just Bought Four Cab-to-frame Mounts For A 67 F-100. Does Anyone Have Experience Taking The Old Mounts Out And Inserting The New Ones? How Do We Lift The Frame To Extract Old Bushings And Install New Ones? Thanx!
Old Feb 21, 2006 | 07:23 AM
jowilker's Avatar
jowilker
WOFP, I think I would remove the 4 bolts, and jack up the back of the cab and replace the rubber. Lower it back down and put in new bolts.
John
Old Feb 21, 2006 | 10:01 PM
thesprocket26's Avatar
thesprocket26
Jowilker, what is WOFP? I would personally lift the cab to replace the mounts. It wouldn't matter how high you lifted the frame unless you have your truck up side down. Take out your bolts, use a floor jack and a 4x4 piece of steel to jack up your cab. New bolts are a great idea.
Old Feb 22, 2006 | 04:30 AM
jowilker's Avatar
jowilker
Dear friend, I have no idea, but like thesprocket26 it's what the poster used as a screen name.
I presumed that WOFP's truck was still together and in use. One wouldn't want to seperate the front clip from the cab to install new rubber mounts. The cab and clip have 6 mount points, 4 under the cab and 2 under the radiator support. Using a floor jack as you suggested and lifting the rear of the cab as I suggested with the radiator support still connected should allow you to slip the old pieces out and the new in. IMHO In My Humble Opinion
John
Old Feb 22, 2006 | 06:20 PM
WOFP's Avatar
WOFP
Thanks for the note and the suggestion on the 4 x 4! And I think I'll leave the frame on the deck and lift the cab...
Old Jul 15, 2006 | 06:51 PM
WOFP's Avatar
WOFP
Lifted cab and knocked out old mounts forward. Unfortunately the LMC bolts are too long and there is a lot of play in the newly installed mount set. The bolt is 3 and 3/4" long, and it looks like it is about 3/4' too long. Does anyone have an idea. Perhaps I ordered the wrong set, but i don't think so...Maybe replacing the long bolt with a shorter one will suffice...?
Old Jul 17, 2006 | 10:35 PM
ford1967's Avatar
ford1967
no lmc's kit is like that i just went to the hardware store and bought some grade eight bolts. you bought the right kit
Old Jul 23, 2006 | 05:44 PM
WOFP's Avatar
WOFP
Question
Combined bushings and hardware for fore and aft cab mounts to successfuly install two middle cab mounts. Had to "whiz wheel" one rusted bolt off. This week, I want to order two more mounts---the ones furthest forward and outboard of the radiator---but I'm a bit leery of the LMC hardware now. Does anyone have a better source for new and proper fitting cab mounts?
Old Jul 23, 2006 | 06:30 PM
my72ford's Avatar
my72ford
you can try dennis carpenter in concord north carolina..they have some good parts made from original ford tooling.a little high but well worth the $
Old Jul 23, 2006 | 07:21 PM
WOFP's Avatar
WOFP
Question
Thank you! Might you have some contact info? v/r, WOFP
Old Jul 24, 2006 | 05:44 AM
jowilker's Avatar
jowilker
Try this http://dennis-carpenter.com/
John
