starter button
Old Feb 20, 2006 | 07:47 AM
mike432's Avatar
mike432
starter button
is it possible to install a starter button on a 1980 ford f-150? none of the wires in the steering column seem to make the starter motor crank. any advice would be appreciated. thanks. mike
Old Feb 20, 2006 | 08:44 AM
Sycostang67's Avatar
Sycostang67
If the truck will run with the key in the on position, you can jump the solenoid to get it to fire up. Sure you can put a starter button on it.
Old Feb 20, 2006 | 10:48 AM
Torque1st's Avatar
Torque1st
Posting Legend
It is better to get the OEM wiring to work especially if you are unfamiliar with electrical wiring.
Old Feb 20, 2006 | 05:40 PM
69oiler's Avatar
69oiler
i have a starter button on my '86. the start position quit working, installed a new ignition switch, adjusted, re-adjusted, still no dice. so in went the starter button. just make sure you install a fuse between the button and the power source. then run your lead to the starter solinoid.
