Sponsored by: Innova
95 Windstar blown amp
Old Feb 19, 2006 | 11:00 PM
Buggie's Avatar
Buggie
Hi,
I have a 95 windstar with the premium sound.
Not had any sound out of the speakers since I bought it (about a month ago) though I do get sound out of the rear headphone sockets.
Finally traced it to a blown amp. Got another amp and still not working.
There are 2 connectors going to the amp, an 8 pin that comes from the radio and then an 11 pin, 8 of which go to the speakers, 1 ground and 1 is a 6V line coming from the radio (when the radio is turned on - presumably telling the amp to 'turn on') the last wire I'm presuming should be the +12v (purple with blue stripe) as it happens all the damage inside the old amp was on this pin - but there is no 12V on this wire, I've checked the fuses and these are good.
I know I could just pull the old radio and install something newer with the relevant by pass cables, but I like the idea of the rear headphone sockets / controls which I would lose with a new one, plus I've already sunk money into a replacement amp.
I guess my next thing is to cut the original 12V wire and find another 12V source to see if things then work, before I do this though I thought I'd see if anyone had any other ideas or knew if there was any sort of relay on this wire?
Thanks
James
Old Feb 20, 2006 | 10:17 PM
IPACA9's Avatar
IPACA9
the issue you will run into if you put a new radio in is that you have to wire past the headphone jacks. I remember these vans because of that issue. It would overheat a radio.
Staceman
Aerostar
20
May 30, 2020 12:29 PM
Raptr241
Feb 28, 2020 12:12 PM
lbcarguy
Jan 20, 2013 08:05 PM
TallPaul
15
Aug 6, 2009 08:39 PM
