Swap Meet Prices
Old Apr 27, 2001 | 02:45 AM
koto's Avatar
koto
Swap Meet Prices
What are some good swap meet prices for the ford stuff on this list??
ford auto trany bell housing to fit an fe Big block 3 speed
ford 390 pair of heads
ford 390 gasket set
ford 390 2 barrell intake
ford 390 distributor Points
chevy small block hei distributor
buick 231 distributor
buick 231 2 barrel intake
buick 231 2 barrell aluminum intake
chevy small block 4 barrell intaka cast
390 4 barrell intake cast
chevy a/c compressor
chevy power stering pump
390 stock fans
set of 4 steel rims off of a 90's wrangler
old air compressor tank
new 2 cyl air compressor pump
harmonic ballancer's for 231 buick
carter 2 barrell carberator
stock air cleaner for 83 chev truck
350 hydromatic and tork conv long shaft
390 watter pump
390 starter
and a partraige in a pair tree
Hoping to sell this stuff at a swap meet this weekend. Just do not know what it is worth Thanks
Old Apr 27, 2001 | 12:14 PM
dzjammer's Avatar
dzjammer
Swap Meet Prices
If its at the same swap meet I'll be at, it isn't worth anything. Otherwise, as much as you dare to ask.
Dave,
79 F-150 4x4, 390 w/C6, Edelbrock carb, 33X12.50 never will be finished.
Old Apr 27, 2001 | 03:19 PM
mattb's Avatar
mattb
Swap Meet Prices
what swap meet? Jefferson WI? if so than its not worth much except for the chevy stuff, it seems that is all they ever have there. almost like a chevy swap meet.
mattb
Old Apr 28, 2001 | 10:49 PM
davido's Avatar
davido
Swap Meet Prices
SOUNDS LIKE THIS WILL BE YOUR FIRST SWAP MEET, EVERY TIME I GO THEY THINK THE PARTS ARE PLATED IN GOLD, LOOKS LIKE YOU NEED ALOT OF STUFF, IF I WERE YOU GO TO THE SWAP MEET AND CHECK OUT ALL THE STUFF FOR FUN AND YOU MIGHT GET LUCKY, BUT THEN I WOULD GO TO A SALVAGE YARD OR JUST CHECK THE CLASSIFIDES, OR BUY A PARTS TRUCK, GOOD LUCK WHERE IS THE SWAP MEET
Old Apr 28, 2001 | 11:19 PM
koto's Avatar
koto
Swap Meet Prices
Meet was in cleves ohio,,, and it was the wrong place to take the ford stuff really didint get a second look,, If anyone is interested in anything listed let me know,,,
Old Apr 28, 2001 | 11:48 PM
whomrig's Avatar
whomrig
Swap Meet Prices
