Offroad & 4x4
i need pictures
Old Feb 19, 2006 | 08:09 PM
chrono4's Avatar
chrono4
i need pictures
im trying to decide how to mount my front eyeletts of my leaf sas, and i just cant figure the best way to do it. i thought about mounting them back like / from my bumper, but want to see how someone else made it work. i need to be about as far foward as posiible, but i dont want to go straight down with them l . pictures anyone?
Old Feb 19, 2006 | 08:20 PM
Franken-Truck's Avatar
Franken-Truck
You mean the front spring hangers? I got a few pictures of my '78 stock setup, if thats what your shooting for?
Old Feb 19, 2006 | 08:26 PM
chrono4's Avatar
chrono4
yeah, i need pics of the front front springs.
Old Feb 19, 2006 | 08:31 PM
RawPower's Avatar
RawPower
Are you trying to get lift out of it?
Old Feb 19, 2006 | 08:32 PM
chrono4's Avatar
chrono4
yeah, ive got to clear the crossmember, and 35's.
Old Feb 19, 2006 | 08:46 PM
RawPower's Avatar
RawPower
Well I dont have any pics because I havent made one yet, but this is what my front hangers will look like. You can do womthing similar, but your bolt holes that bolt onto the frame wont have to be where mine are in the design. I dont know if the 88's had the front of hte frame boxed in or not... If it doesnt then get some C-channel and box the front in the SAME WIDTH as your leaves will be. That way you wont have to puit a bend in the metal like my design. My truck has the front boxed in and the frame is 3" while the leaves are 3.5" with the bushings...
http://www.supermotors.org/vehicles/....php?id=291885
Edit: clearing hte crossmember will be a bigger issue than the 35's.
My design gives 6" of lift on a 93-94 F350 but I cant say how much it would give you. I would design your own and not use my measurements...
Edit 2: how much lift would you get from swapping IFS w/ coils to a SAS w/ leaves
Old Feb 19, 2006 | 10:15 PM
Franken-Truck
Heres my stock front hangers for my '78
https://www.ford-trucks.com/user_gal.../83576.520.390
Raw's design is pretty much an elongated version of what was stock in the 70's. However much lift you need up front, just make it longer like Ivan, pro, ramboss, and others have done. Beef up your front end, maybe cross brace the brackets as well.
And if it breaks and you wreck. . .we never met
Old Feb 19, 2006 | 10:26 PM
RawPower's Avatar
RawPower
DEFINATELY do a crossmember between the front hangers if they are elongated...
So far Pro's is the stoutest Ive seen. Then again he needs it more than most.
Old Feb 19, 2006 | 10:30 PM
Flareside94's Avatar
Flareside94
Just be thankful you don't have a crumpe zone to deal with like 92-96 F150's.
Old Feb 20, 2006 | 01:05 AM
mustange70's Avatar
mustange70
Take a look in my gallery of the old lift and the new stuff i'm building, might give you an idea, oh and i've boxed the front frame rails and added an additional crossmember in addition to the shackle mount/bumper.
Old Feb 20, 2006 | 11:12 AM
ramboss429's Avatar
ramboss429
Bronco to Leaf SAS
My Hangers
I think for what you are needing to do, the first link I sent you will be your best bet. I still have to box my frame rails and do some other tweakin on my setup.
Old Feb 20, 2006 | 02:40 PM
chrono4's Avatar
chrono4
thanks guys, im looking through those right now.
Old Feb 20, 2006 | 09:22 PM
mustange70's Avatar
mustange70
because i'm really board right now, to make it a little easier for you:
https://www.ford-trucks.com/user_gal...101924&width=0
https://www.ford-trucks.com/user_gal...101925&width=0
Old Feb 21, 2006 | 03:35 PM
chrono4's Avatar
chrono4
thanks mustang, thats what i was looking for.
