A/C Hose assembly - Part help!
Old Feb 19, 2006 | 11:52 AM
kc7smo's Avatar
kc7smo
Hey Everyone,
My 1988 F-150 351W with factory air has a leak on the hose assembly, drivers side, right where the fitting is. It leaks around the edge where the fitting sticks up from the actual hose. I have found AC DELCO part 1531389, however I was told that it is only the rubber hose, and not all the metal fittings. Is this true? I didn't know the rubber hose could come off the metal for replacement.
Here is a picture of the ACDELCO part. http://www.rockauto.com/ref/ACDelco/...l?15-31389.jpg
I don't know why, but if you copy and paste this link into your browser, the image shows up, otherwise it won't.
Old Feb 19, 2006 | 08:51 PM
Ultramagdan's Avatar
Ultramagdan
Either way you need to have your freon sucked out before you can replace the hose (unless it's already escaped). I would replace the assembly.
Old Feb 19, 2006 | 08:56 PM
kc7smo's Avatar
kc7smo
Yeah, the freon is long gone. It was actually converted to R134a a few years ago, but now its leaking again. I just am not sure if that part is the entire assembly or not. Rockauto's website says if the picture has some of the parts in white or clear, that they are not part of the product you are buying. I just don't see how that hose can be sold without the entire assembly. I would think that that whole unit is replaced at once, and that the individual hoses cannot be replaced on there own. Am I wrong in that assumption, or what???
Old Feb 19, 2006 | 09:12 PM
Ultramagdan
You should be able to replace individual hoses but lack of availability may make the assembly the faster way to go sometimes.
Old Feb 24, 2006 | 10:40 PM
kc7smo's Avatar
kc7smo
Got a hold of AC Delco, just in case anyone was wondering. That part number if for the WHOLE metal assembly that bolts to the top of the compressor, including the long hose going to the other side of the engine and the short one going to the condensor unit up front.
Just wanted to let anyone know who may be interested.
Old Feb 25, 2006 | 07:42 AM
Ultramagdan
Thanks KC for the info!
Old Feb 26, 2006 | 10:02 PM
sctrt's Avatar
sctrt
If the hose is bad and a new one is costly, then look for a good A/C shop and they will make you a new hose.
miz
Jul 15, 2014 09:20 AM
petes79f150
Oil & Lubrication
Sep 12, 2007 10:04 PM
Golfmore
Oil & Lubrication
Jul 21, 2004 08:52 PM
jamlove
Dec 11, 2003 11:52 AM
