Wheel bearings
Old Apr 26, 2001 | 08:42 PM
Franklin2's Avatar
Franklin2
Wheel bearings
Old Apr 29, 2001 | 06:02 PM
9inchxj's Avatar
9inchxj
Wheel bearings
Where's the best place to get rear 9" wheel bearings, seals, races and retainers? Prefer a heavy duty version if avaliable. Also, is changing these a job that can be done at home or do you need a press, etc?
Old Apr 29, 2001 | 09:38 PM
MSTRAWN's Avatar
MSTRAWN
Wheel bearings
Any auto parts store should have the parts that you need. A press will be necessary to install the new bearing. Save yourself some money by removing the old bearings yourself. A good chisel and large hammer to split the retaining ring, then a few taps on the old bearing and they should come right off. Mike.
1977 F-100
300 I-6 / C-4 (soon to be AOD)
Offy intake w/Edelbrock 500CFM
Hooker Ceramic coated headers w/duals
MSD6
Whiter whites/Brighter brights
Old Apr 30, 2001 | 08:53 AM
William's Avatar
William
Wheel bearings
Wear your safety glasses whenever your chisling on steel. I take the axles with the old bearing still on and the new bearings to any machine shop.
William in Atlanta
