589 gear problem
Old Feb 19, 2006 | 11:18 AM
tess100's Avatar
tess100
589 gear problem
i am trying to instal 589 gears in my dana 60 with nothing but problems .first i put gears in and found out they woudnt work because carrier was for 353 gears, then i got a spacer ring to solve problem, now when i put it together i cant get center pin in because ring gear is past the hole 1/2 inch. i cant put pin in first because then i cant get c-clips on axeles, now what ? . i thaught maybe buy a spool but still dont now how c-clip axles will work, is ther a spool desihgned for this diff ? truck is off road only. thanks in adv wayne
Old Feb 19, 2006 | 12:37 PM
tess100's Avatar
tess100
never mind i found my answer on randys ring pinion site. grind center of cross shafdt
