1978 - 1996 Big Bronco
yay green! : (
Old Feb 19, 2006 | 10:27 AM
wozxxx86's Avatar
wozxxx86
yay green! : (
well lastnight was in the negatives. and now i got a green pool under my truck. other then a cracked block what else would give? i didnt see any freez plugs out. all hose's and rad are good to. the leakeage is under the fron of the motor.
Old Feb 19, 2006 | 10:43 AM
WhëëlMå1's Avatar
WhëëlMå1
Seam probably let go on the radiator.
Old Feb 19, 2006 | 02:19 PM
wozxxx86's Avatar
wozxxx86
nope i checked.. not a trace of coolant close enough to it and not a drop any where on it. theres some on the damper tho. and on either side on acc's. but i checked the hoses there good to go. can the seal on the pump get ruptured by ice?
Old Feb 19, 2006 | 07:13 PM
greystreak92's Avatar
greystreak92
Check the water neck for cracks. Coolant can get trapped in/above the thermostat and in that small quantity (and if its been in there a while) can freeze and crack it. Water pump itself may have cracked too.
Old Feb 19, 2006 | 11:19 PM
wozxxx86's Avatar
wozxxx86
...pift. it does look like the water pump is cracked. damn. well i guess i just wait till i get my pay check and fix it with a new motor ; ) lol. just means i have to drive a chevy for a week : ((
Old Feb 20, 2006 | 08:50 AM
Kemicalburns's Avatar
Kemicalburns
at least its only the water pump. a cracked block would suck
Old Feb 20, 2006 | 08:53 AM
Streetgang's Avatar
Streetgang
Get it someplace where you can work on it.....its way too cold out to try to do it caveman style in the driveway. Clean it up a bit and then pressure test the system.......just keep your fingers crossed that it is not a major problem
Old Feb 20, 2006 | 01:38 PM
wozxxx86's Avatar
wozxxx86
yea lol i hadnt planned on workin in the cold. ima take it to where i work and pull it inside and take a looksie
