Sponsored by: Real Truck
Transmission service
Old Feb 19, 2006 | 09:30 AM
Raptor1's Avatar
Raptor1
I've got an 04 CC that I'm bringing into the dealer tommorrow for a transmission flush. Should I have them change out the external filter when doing the service? Also, how easy is it to do myself? I've seen pics of where it sits, just don't know if I have to disconnect return lines, etc when changing the filter. Thanks
Old Feb 19, 2006 | 10:21 AM
Rongold's Avatar
Rongold
Question Trans Filter
The only trans filter that I know about is inside the pan.
RON
Old Feb 19, 2006 | 10:46 AM
EnviroCon's Avatar
EnviroCon
Which tranny do you have?
Old Feb 19, 2006 | 11:40 AM
1buzzbait's Avatar
1buzzbait
--suggest changing the internal filter(if ya have external you some kinda fancy mod)along with the flush,,$$ a little more
Old Feb 19, 2006 | 11:55 AM
EnviroCon's Avatar
EnviroCon
Originally Posted by 1buzzbait
--(if ya have external you some kinda fancy mod)
If he has the Torqueshift, they come stock with an external in-line filter. Bear Hunter did a great write-up on Flushing the Torqueshift.
Old Feb 20, 2006 | 08:55 AM
Raptor1's Avatar
Raptor1
Sorry, yes it has the torqueshift which has that external filter. I read that article, but couldn't tell if you can take it off without disconnecting return lines or something else.
Old Feb 20, 2006 | 05:58 PM
Casey's Avatar
Casey
The filter housing unscrews without removing the lines. It's a 1 minute job to change. I'd have it done.
Old Feb 20, 2006 | 06:09 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
No matter what, whenever you have your trans fluid flushed, you should always have the filter changed. It may cost a little extra but it'll save you a new transmission in the long run.
Tact
Oct 18, 2013 01:54 PM
Tact
Oct 17, 2013 06:05 PM
Tact
Oct 17, 2013 07:19 AM
ktf71096
Aug 26, 2013 12:53 PM
mtconley
6.4L Power Stroke Diesel
Mar 26, 2012 06:29 PM
