I have an 82 F250 longbed/standard cab. What beds will swap with no modification to my frame? My bed is shot and i'm not having luck finding one in "decent" condition. I realise the body lines might not match for newer years, but are the mounting points the same? Thanks!
From what I have been able to determine, any 1980-96 bed of the same design will fit. Too bad you're not closer to me, I have a 1990 F250 longbed/standard cab I am parting out. The bed is in pretty decent shape.
The wheel wells are also rounded on the 87up and straight across the top on earlier.
I recently put a 87 bed on my 83 and the gas filler barely reaches the opening in the bed, it looks like the mounting flange on the filler tube is the wrong angle also.
I went back to the j-yard and got the filler tube for the 87, it doesn't look longer, maybe the rubber connecting hose from the filler to the tank is longer on the 87.
