Electric rear locker
Old Feb 18, 2006 | 04:22 PM
rkcarguy's Avatar
rkcarguy
I just picked up a 1994 F150 ext cab, had another post up already:
"Got my truck, got a coolant leak"
I was playing with the 4wd and noticed when I was in 4wd the truck seemed to be harder to turn. Seems it has an electric locker installed, there's some wires and stuff going into the rear diff on the top of the pumpkin. Was this a factory option or did someone install this? Theres no switch or anything just in 4wd it posi's up pretty solid.
Old Feb 18, 2006 | 04:53 PM
DaveBowman's Avatar
DaveBowman
Thats not a locker. The wires are going in to the rear axle speed sensor. Its an eccentric ring on the differential that works the speedometer, and rear ABS.
Its always going to be hard to turn the truck if your locked in 4 wheel drive, thats normal. Don't do it on pavement or hard dirt or any place you don't need 4 wheel drive
Old Feb 18, 2006 | 06:10 PM
chrono4's Avatar
chrono4
harder to turn meens harder on your driveline. dont drive on pavement in 4wd, it binds it all up.
Old Feb 18, 2006 | 06:51 PM
rkcarguy's Avatar
rkcarguy
It was in gravel don't worry. I'm going to jack it up tomorrow and see whats really under there.
Old Feb 18, 2006 | 08:15 PM
kc7smo's Avatar
kc7smo
Unless there is two seperate sets of wires going to the rear pumpkin, its definatley for the RABS. If you want a rear electric locker, Eaton makes one, Lowest price I've seen is 650.00 with free shipping from http://www.4wheelerssupply.com
Old Feb 18, 2006 | 10:11 PM
rkcarguy's Avatar
rkcarguy
Thats what I'm going to check for tomorrow, + jack it up and see if it's posi at all.
