Sponsored by: Kumho
removing spring bolts....how ?
Old Feb 18, 2006 | 01:07 PM
Hyperactive460's Avatar
Hyperactive460
i'm in the process of getting more lift but i'm having trouble getting the bolts out of the sleeves. the nuts are loose but the bolts just won't budge.....
Old Feb 18, 2006 | 11:05 PM
someday's Avatar
someday
they most likely r probably fused together which means they r not coming out...i recently worked on my springs myself and some looked like they 'melted' together...just for fun i tried to get them out with a three foot cheater bar, sledge hammer, and whatever else i could find and they did not come out
you r going to have to cut or grind the head of the bolt off or cut the bolt between the hanger and spring...you could also torch the head off which if u do yourself u will probably be carefull and not burn up the hanger like some jack a$$ previously did...lastly, i also used energy suspension poly bushings and used a lot of their grease...it is real tacky with teflon that u can even get at autozone
Old Feb 19, 2006 | 08:47 AM
Hyperactive460
yeah.. i figured that thats what i'd end up doing. was just hoping for another way if there was one......oh, and thanks for the reply
Old Feb 19, 2006 | 11:07 AM
rebocardo's Avatar
rebocardo
Best way is to burn the rubber out, then remove them, then grind/cut one side of the metal bushing down to the bolt, insert into a vise, then air hammer the bolt out. You can air hammer (or impact) the bolt out using a big enough air hammer or impact while in the truck. Make sure to put antiseize on the whole bolt when you put it back in.
