transfer case
Old Feb 18, 2006 | 06:05 AM
trucker41's Avatar
trucker41
transfer case
Have a 83 ford F350 I four wheel drive makes a clunking noise was told there is a chain inside transfer case that is probably sliping. Is there any way to tightin it up or do I have to replace it? If so how hard is it to do.
Old Feb 18, 2006 | 06:41 AM
The SnoMan's Avatar
The SnoMan
Usually it clunks and snaps if it is slipping. Sometime they can slapp around in tcase and make noise when worn. Thye are not that had to change and there is no adjustment. Usually they last a will if lubed and gear properly but if you have big tires with stock gears they can sometimes go to a early grave.
